2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-29T16:55:38+00:00
    So, Microsoft uses these devices to compete against the iPad in the education space.  Imagine if you were the decision maker at a school district that was going to buy thousands of devices for classroom use seeing these types of problems and the response leaving customers swinging in the wind.  These were not designed to be a 1 year throw-away.  But, of course, those folks are under a software agreement and likely some type of warranty or service agreement.  Microsoft needs to fix this soon not only for the existing customers, like those of us on the forum here, but to salvage their reputation in the corporate and pub sector area too.  They need to understand the potential cost not only to address these very visible issues but also the loss of sales going forward.
    Hopefully, the crickets response we are getting will end and a suitable solution will be offered.  Somebody at the GM level or above needs to understand that this is not an accounting decision, it's a reputation decision.
    2016-07-29T17:11:06+00:00
    I will be very impressed "IF" Microsoft really fix this issue with a firmware update.
    Remember Microsoft said about 2 years ago that they were going to release a fix for the jitter diagonal lines of the surface pen by increasing the voltage?!
    Microsoft....we haven't forgot that.....and we are all still waiting.
    2016-07-29T18:24:39+00:00
    I am holding out hope, and the more I think about it, the more I think it may be possible to fix in software / firmware. Since we have now seen at least a few cases where the LG batts have seen some pretty significant capacity degradation as well, that might even point more to software vs bad battery cells.
    There is some charging circuitry to charge the batt and communicate the battery status to windows. Battery chargers generally use some type of "voltage profile" to determine when a battery is nearing or has reached it's fully charged state. So if these batteries as they normally degrade from use start to exhibit a slightly different profile, the charging firmware might be too sensitive to some normal condition of an older battery, thus giving a "false positive" of fully charged status. That type of thing could certainly be fixed in firmware.
    Also, as far as more modern batteries go, the manufacturing is pretty consistent overall, and "bad" batteries from a batch might degrade quicker or have less overall capacity, but it seems unlikely there would be a large batch, especially across at least 2 MFRs now, that would show this huge cliff drop within a short few months.
    I have a slight hunch that maybe the charging circuitry might even take into account the "expected max" based on previous charge cycles, and that might explain why it would keep dropping so fast. Who knows, I am just speculating.
    But the one cool thing about this issue is, that with the included powercfg /batteryreport tool we are all using to report our findings - we have a smoking gun to display EXACTLY when and how bad our issue is. So there is no way the company or any support person can deny that this is WAY outside normal wear and tear. There is nothing subjective about it when their own tool is telling them exactly what we are seeing!
    2016-07-29T19:03:58+00:00
    is this a retail or enterprise/education version of Windows?
    you should be at 10586.494
    check windows updates.
    >>OS BUILD 10586.212.amd64fre.th2_release_sec.160328-1908
     I just re checked windows updates they downloaded onto the surface ok  but wont install as I dont have 40% battery charge
    11%  plugged in not charging
    if there is a software update to fix this problem ,does it mean  it wont be any good to me as i cannot update due to not having  40% battery life ?
