2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-29T15:35:43+00:00
    Hi, I have a Surface Pro 3 which went out of warranty in February of 2016.  The Battery Report indicates as follows:
    2016-07-28 733 mWh 42,157 mWh
    Clearly the battery is dead.  How do I contact Microsoft to discuss replacement of the battery?  Do I have to pay $99 just to speak with someone about replacing the battery?  How much does the replacement cost, what is the process and what is the timeframe?
    Thanks!!!
    2016-07-29T16:10:19+00:00
    Add me to the list as well.  The drain on mine started in May, and is now this:
    I have the SIMPLO battery, and it's cycled 162 times.  Full charge capacity is 502 mWh.
    Bought it in February 2015, so I'm out of warranty, but infuriated at the thought of paying $99 just to speak with someone about it.  Insane!!!  I understand there is a firmware fix that should take care of it?  I downloaded and installed new firmware today, so we'll see if this is the touted fix.
    Thanks Microsoft. . .
    2016-07-29T16:11:15+00:00
    2016-07-29T16:34:34+00:00
    The recent firmware update is not going to fix the issue. They still have yet to announce the actual fix, but I am hoping something will be done by the Aug 9th normal patch day. My SP3 is basically a useless brick right now.
