2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-28T20:03:43+00:00
    I see posts indicating not all SIMPLO batteries necessarily have a problem. I can cite yet another. My cousin and I both bought our Surface Pro 3s about the same time. Both sport SIMPLO batteries. My battery had dropped below 50% (& falling) while hers was still around 94%. However, mine was a relatively high cycle count (300+) versus 32.
    Since my unit was just inside the warranty window I pursued this via Support and when their intervention didn’t do the job I took the swap out option. Microsoft handled that very well; high marks. However, I did note in the couple of days just prior to shipping off my Surface Pro 3 that the battery report showed a capacity increase from 20k to 22k mWh. I would sure have loved to see what was in store for that unit, but there was no way I wasn’t going to jump on the warranty swap while it was still available.
    My replacement Surface has an LGC battery and I had been feeling lucky on that score. Maybe I was being hasty. It would be interesting to know what percentage of units shipped with which brand battery. Perhaps the LGC is uncommon?
    2016-07-28T20:14:41+00:00
    I have the LG battery around the same degredation and i have only  really used it when away from home 3 or  4 times a year
    I use a desktop at home
    and now it looks like i have a mobile desktop  as well
    my surface  will not work with out power cord and is now showing 13% plugged in not charging  from 97% plugged in not charging a couple of  months ago
    2016-07-28T20:52:59+00:00
    I've had my Surface Pro 3 for 18 months. Love the device with WIndows 10. Unfortunately, I am in the same position as the others on this thread. The battery capacity is now below 1000 and the device will not run unless plugged into the charger.
    I expect wear on the battery over time but not like this. There is clearly a general class problem with the device.
    2016-07-28T20:57:01+00:00
    Hi Kridsada,
    Now that the number of people with the problem is in the 100's have you had any luck getting your costs back from Microsoft yet?
    Simon
