2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T23:38:36+00:00
    Why would the SIMPLO batteries have this problem and need a software fix but not the LG ones?
    That's the part that I am having a tough time figuring out myself.
    Granted, I don't know a lot about the intricacies of battery charging circuitry/software, but the sloping decline rather than immediate dropoff sounds more like a battery chemistry issue than a software/firmware issue. I guess it is possible the SIMPLO batteries give a false-positive voltage leveling off that the LGs do not? Who knows.
    But I shall stay tuned to find out where this goes.
    2016-07-27T01:44:30+00:00
    Hi, The model of the battery is behind the stand... see below.
    2016-07-27T09:18:37+00:00
    Based on our investigations we can confirm that it is not an issue with the battery cells, and we believe this is something that can be addressed via software.
    Thank you for the update, although I would like to know why it took this long to acknowledge the problem here, and really hope this can be resolved through a software update.
    While not affected I would hope Microsoft will be compensating all those who paid the $99 for support and in particular anyone who has paid $450 to get the issue fixed.
    Look forward to the "fix" which hopefully arrives soon.
    2016-07-27T09:19:46+00:00
    Looks like the image didn't come through. Can you repost?
