2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T21:26:21+00:00
    Amin?  How about I set up a professional support case to get this looked into.  Email me at susan-at-msmvps.com (change the -at- to @) and I'll need your phone number to set up a call back.  It will be a free case for you.
    2016-07-22T21:32:11+00:00
    Me too?
    2016-07-22T21:57:53+00:00
    Let me add myself to this list. started having this issue just before the warranty ran out they said watch for 15 days, now damn thing powers down like crazy.
    Ran the tool.. It is a simplo battery.
    2016-07-22T22:22:19+00:00
    This update did nothing for the battery. still at 144 mWh capacity. c'mon Microsoft please make this right.
    Exactly! Perhaps this update will prevent the new batteries that MS should issue at no cost, but did nothing for my current dead battery. Like a fool, after the update, restarting, etc. I unplugged the charger and of course it shut down. Sucks!
