2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-20T12:59:37+00:00
    I am seeing the same issue where my battery life is typically around 2 hours.  Here is my latest battery tyep and life estimates:
    NAME X904849
    MANUFACTURER SIMPLO
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=d3cde56c-bf5c-42ba-9049-a58e1c3562a0)
    2016-07-20T13:15:02+00:00
    my surface is not that old but I struggling with battery and powercod
    2016-07-20T13:15:54+00:00
    If your  surface  is under 2 years  and based in the UK take it back to the shop
    quote sale of goods act and they need to give you 2 years guarantee
    2016-07-20T15:58:02+00:00
    Same for me. 507 cycles in total and since about 6 weeks battery capacity is decreasing rapidly to 22 Wh now. Continuing like that I won't be able to use my surface without power cord in 3-5 weeks. Hardware warranty until 02/2017, hope this also includes this battery problem and Microsoft will replace it without any fees.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8992b4ba-9c8b-4550-b608-1d74643f0fad)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=6f7575b6-916a-45a8-b1cc-834828419525)
