2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-20T11:52:42+00:00
    Same issue here, hope to get some response from the Surface support team, did you get any resolution. My Surface is just out of warranty.
    2016-07-20T12:06:44+00:00
    Live Tweet it with the hash tag #batterygate 🙂
    2016-07-20T12:35:19+00:00
    I was lucky. I took out an extended warranty when i bought my SP3. so its covered until may 2017. there was no discussion on the live chat. simply stated my battery full charge capacity now and what is was in may and he arranged a UPS delivery note for me to send mine to Germany. They will then send a replacement back.
    apparently, i will be without a machine for 5-8 days.
    seems they all have been briefed about the issue
    2016-07-20T12:58:44+00:00
    Just been on the support chat:-
    Support Tech: Now, the problem with the battery is hardware issue, so what I can do for you in this situation is to process a replacement for the device. But since the device is no longer in warranty, you would need to pay a certain amount for this exchange
    Me: How much would that be please?
    Support Tech: That would be £333.33 + taxes
