2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-07-20T08:59:06+00:00
    But let's not sink this thread, keep it active until Microsoft gives us a formal explanation.
    Agree 100% -- please keep posting new info and if you have access to feedback hub search for "Surface Pro 3 Battery Degradation" and up vote. :)
    Actually just searching for "Surface Pro 3 Battery" yields a high number of hits so looks like many are suffering from this but putting it down to recent Insider slow/fast ring builds.  I hope the Microsoft response of "we are aware" is our issue and not just battery life in general.
    2016-07-20T09:40:05+00:00
    In my case, the generated report does not show the actual battery capacity. It can be checked using external programs.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b0c87008-e995-48ca-a5f6-b71738edd8bb)
    COMPUTER NAME SURFACE
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.494.amd64fre.th2_release_sec.160630-1736
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-20 11:31:35
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163401732
    CHEMISTRY LION
    DESIGN CAPACITY mWh
    FULL CHARGE CAPACITY mWh
    CYCLE COUNT 85
    Recent usage
    Power states over the last 3 days
    2016-07-17 13:13:02 Connected standby AC 100 % mWh
    15:00:13 Active AC 100 % mWh
    15:00:42 Connected standby AC 100 % mWh
    2016-07-18 11:15:09 Suspended 100 % mWh
    11:33:40 Active AC 100 % mWh
    13:06:28 Connected standby AC 100 % mWh
    15:51:38 Active AC 100 % mWh
    16:10:00 Connected standby AC 100 % mWh
    16:24:43 Active AC 100 % mWh
    16:35:45 Connected standby AC 100 % mWh
    16:40:08 Active AC 100 % mWh
    17:25:29 Connected standby AC 100 % mWh
    19:54:18 Active AC 100 % mWh
    21:06:24 Connected standby AC 100 % mWh
    21:06:59 Active AC 100 % mWh
    22:35:00 Suspended 100 % mWh
    2016-07-19 10:42:53 Active AC 100 % mWh
    10:52:56 Connected standby AC 100 % mWh
    11:25:43 Active AC 100 % mWh
    14:43:42 Connected standby AC 100 % mWh
    15:06:29 Active AC 100 % mWh
    19:20:00 Connected standby AC 100 % mWh
    19:39:51 Active AC 100 % mWh
    21:39:00 Suspended 100 % mWh
    2016-07-20 10:46:19 Active AC 100 % mWh
    10:56:21 Connected standby AC 100 % mWh
    11:14:29 Active AC 100 % mWh
    11:31:00 Report generated AC 100 % mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2016-05-20 - 2016-05-27 0:22:58 0:01:45 61:10:33 16:22:00
    2016-05-27 - 2016-06-03 1:10:24 0:02:33 57:35:54 11:38:12
    2016-06-03 - 2016-06-10 1:06:54 0:01:36 58:16:25 5:15:05
    2016-06-10 - 2016-06-17 0:03:24 - 63:25:29 26:09:57
    2016-06-17 - 2016-06-24 1:02:06 0:32:45 69:37:44 34:45:53
    2016-06-24 - 2016-07-01 0:04:18 - 1:36:21 14:24:13
    2016-07-01 - 2016-07-08 - - - -
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 - - - -
    2016-07-13 0:00:09 - 9:46:52 -
    2016-07-14 - - 10:50:12 0:38:36
    2016-07-15 - - 3:10:46 9:49:26
    2016-07-16 - - - 23:59:46
    2016-07-17 - - 0:00:29 23:59:17
    2016-07-18 - - 5:27:30 16:48:35
    2016-07-19 - - 9:40:30 1:15:23
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-05-20 - 2016-05-27 mWh mWh
    2016-05-27 - 2016-06-03 mWh mWh
    2016-06-03 - 2016-06-10 mWh mWh
    2016-06-10 - 2016-06-17 mWh mWh
    2016-06-17 - 2016-06-24 mWh mWh
    2016-06-24 - 2016-07-01 mWh mWh
    2016-07-01 - 2016-07-08 mWh mWh
    2016-07-09 mWh mWh
    2016-07-10 mWh mWh
    2016-07-11 mWh mWh
    2016-07-12 mWh mWh
    2016-07-13 mWh mWh
    2016-07-14 mWh mWh
    2016-07-15 mWh mWh
    2016-07-16 mWh mWh
    2016-07-17 mWh mWh
    2016-07-18 mWh mWh
    2016-07-19 mWh mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-05-20 - 2016-05-27 2:25:44 - 5:39:43 -
    2016-05-27 - 2016-06-03 1:34:52 2:03:04<br><br>780 % / 16 h 4:39:55 6:03:10<br><br>264 % / 16 h
    2016-06-03 - 2016-06-10 1:12:15 0:30:21<br><br>3163 % / 16 h 4:45:41 2:00:01<br><br>800 % / 16 h
    2016-06-10 - 2016-06-17 0:44:01 - 3:55:44 -
    2016-06-17 - 2016-06-24 0:33:40 3:02:04<br><br>527 % / 16 h 4:14:33 22:56:30<br><br>70 % / 16 h
    2016-06-24 - 2016-07-01 0:06:00 - 0:45:36 -
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 - - - -
    2016-07-13 - - - -
    2016-07-14 - - - -
    2016-07-15 - - - -
    2016-07-16 - - - -
    2016-07-17 - - - -
    2016-07-18 - - - -
    2016-07-19 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:13:38 0:47:02<br><br>2041 % / 16 h 4:14:01 14:35:32<br><br>110 % / 16 h
    2016-07-20T10:23:45+00:00
    I can confirm this too.  Was starting to notice that my surface barely lasted a 1-2 hour meeting on full charge with very minimal web browsing and note taking. Just saw that this is now becoming an issue.
    I really hope Microsoft steps up, and offers some support (for less than $560). This is by far outside the reasonable lifespan of a $1300 product.
