2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-10-03T10:36:30+00:00
    Well said AndyD311.
    I wish everyone would contact the US Lawsuit that Migliaccio in Washington DC have been compiling - EVEN IF YOU ARE NOT IN THE USA CONTACT THEM!
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
    2017-10-03T10:37:09+00:00
    2017-10-03T13:27:38+00:00
    This is specific to simplo batteries, not lgc.
    2017-10-03T13:30:20+00:00
    I would be more than happy to join in if language was edited to include lgc batteries. the lgc battery units are the ones that have become expensive paperweights.
