2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-07-19T04:01:17+00:00
    Mine seem to have fixed itself... almost...
    I still have no battery statistics but at least the battery life is back to almost normal.
    What I did was that at some point in the beginning of this year (or maybe it was the end of the previous... don't remember exactly) I wiped the entire Surface and reinstalled Windows 10 on it.
    Since then I had no issues with the battery (except for the missing statistics...)
    2017-08-11T21:53:59+00:00
    I am extremely disappointed in the Surface Pro 3. The battery life after 11/2 year of service is not good. I have invested over $2K in this "mobile" tablet and it has not lived up to expectations. This SUCKS! The only thing worse, was Microsoft not standing by this product and making users whole by reimbursement or replacement. I will never purchase another Microsoft hardware device again. ARG!!!
    2017-08-11T21:59:16+00:00
    My surface pro doesn't even stay on while plugged into the charger! Disappointed in this con job from Microsoft for $2000 of my hard earned money for electronics they want me to pay to replace after their automatic update broke it!! POS!
    2017-08-12T03:28:21+00:00
    I guess consumer reports is spot on with their terrible review of the Surface and lack of reliability and "no longer recommends" and neither do I.  I have also advised the company that I work for to avoid them.
    I too have a SP3 that no longer detects the battery and can no longer run without being connected to power adapter, that was just out of warranty when it stopped functioning..  Unacceptable Microsoft...
