2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-05-09T17:26:26+00:00
    My Surface Pro 3 is experiencing this issue.  I have not even had it 3 years, but obviously it's out of warranty.  The firmware and solutions online don't fix the problem, and I had sent it in for a battery replacement already when it still was in warranty.  Is there another solution for the dead battery aside from sending it in for $450?  I'd expect a $1200+ system to last more than 2.5 years.
    2017-05-12T17:24:27+00:00
    I have the same problem   Finally got a replacement
    same problem
    have ordered a new power charger   hope that is the problem as a new Surface should charge
    2017-05-15T14:35:13+00:00
    Marlene, Do not order a new charger!  They would probably let you order one, too.
    MS sends replacement surfaces out that have the issue, as the surface pro 3 is no longer manufactured.
     You will have to do the same troubleshooting/fixes.
    I suppose you could ask them to test it before sending it and if the issue is present, test another, and another, until a good one comes up, but they might not even do that.  It's not worth their time, and MS simply doesn't care about the consumer.  They would rather push you to upgrade to a 4, than make their customer happy.
    US: We paid you over a grand for these and you broke it, and now we can't use it.
    THEM:  So?
    2017-07-19T02:47:22+00:00
    one year later, and still no solution?
