2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-02-14T21:00:26+00:00
    go to device manager and update your battery driver, see if that helps
    2017-02-14T21:29:26+00:00
    It says all my drivers are up to date. Firmware, battery, AC adapter
    2017-02-22T04:00:43+00:00
    Split from this thread.
    While it seems my battery(Simplo) will charge, After installing the 1/30/2017 firmware update, my battery percentage now never changing on the taskbar or when viewing a battery report. I'm stuck at 99% but the time remaining seems to be ok, once it has been on a while.
    There has got to be a way to roll the firmware back on these things. MS can't be that stupid to not have a way to do it. Just let me roll the thing back to about a year ago and I'll never update again.
    The idiocy/ignorance at MS is astounding.
    ***Post split by the moderator so others can easily search for the same concern.***
    2017-02-22T22:04:54+00:00
    As a follow up to my issue, it has resolved itself. I read someone saying(who was also stuck at 99% like me) to leave it on the charger until it finally hits 100% and it should work ok from there and that's what happened.
    I put it on the charger last night and when I woke up this morning, it said 100% and as I used it today, my battery level % was showing properly and was going down at a normal rate. So it seems my issue has resolved itself(once I charged it to a full 100%).
