2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-02-06T05:32:41+00:00
    I'm curious, is this "fix" they are sending you supposed to fix your specific battery  issue or the over all SP3 battery issues of poor life? Thanks.
    2017-02-06T14:58:55+00:00
    Interesting, so they shipped a flash drive.  You will boot from it, and it will apply a fix.
    What did it cost you to get it shipped.
    Will be interesting to see what happens, up to this point, Microsoft has completely failed., and made me look like a complete fool to my clients.
    Well?
    2017-02-07T13:34:21+00:00
    As this may surprise you, I am still waiting on the Recovery USB... :(  There were no costs.
    2017-02-07T14:08:05+00:00
    I spoke with Microsoft yesterday also and that usb is just as you said, "recovery/reset" not specifically battery related. Hope it will restore your SP3 to the good old days and stay that way this time.
