2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-01-31T16:30:04+00:00
    Yep, I thought there was hope... but, not today...
    2017-02-01T16:20:10+00:00
    So my Surface Pro 3 started having this problem early this month when I connected it to the internet and let it automatically update. It's gotten so bad, that it won't even stay powered on while connected to either of my two AC adapters, but it happily reports "58%" and "plugged in, not charging." Last time I tried to reply to this thread, it shut down while I was typing mid-sentence, and I was so frustrated that I haven't turned it on since...until last night.
    I tried to download and install the new firmware update, but I can't even get my surface pro to stay powered on long enough to finish the download. From the reports tho, it doesn't sound like this is a fix for us.
    I'm not sure which gets me more livid:
    1. That I bought a $1600 tablet two years ago that may have a true hardware failure (assuming it isn't really the firmware causing my problems) that MS wants to charge me a replacement to fix.
    -or-
    1. That MS potentially broke my tablet with a firmware upgrade that is now so broken it can't stay on long enough to complete a new windows update download/restart cycle that MS wants to charge me a replacement to fix.
    2017-02-02T21:29:46+00:00
    I am in the same boat, however, I may have hope for us.... After being on the line with Microsoft Support, they have shipped me a recovery USB that could potentially repair this issue... I will keep you posted.
    2017-02-02T23:11:42+00:00
    Interesting, so they shipped a flash drive.  You will boot from it, and it will apply a fix.
    What did it cost you to get it shipped.
    Will be interesting to see what happens, up to this point, Microsoft has completely failed., and made me look like a complete fool to my clients.
