2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-01-13T18:03:36+00:00
    Does someone have a link to the November Firmware patch download.  I have a Surface POS 3 I need to try to fix again this weekend.
    2017-01-31T13:27:50+00:00
    The recent November 2016 Firmware Update also killed my Surface Pro 3(Windows 10).  I receive the message "Plugged in, not charging at 66%", and when I remove A/C power the SP3 instantly shuts down.  I have also lost any ability to join a Wireless Connection. The Wi-Fi displays that there are no connections available...But there are.  I really hope Microsoft soon releases a fix for the SP3, as these issues have made it unusable.
    2017-01-31T13:56:51+00:00
    Good Luck, I have been waiting for a fix since July 2016...
    2017-01-31T15:48:20+00:00
    There was a firmware update today........................................................................................ and still the battery is broken.
