2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-12-26T05:29:24+00:00
    I had the same issueI also now have a $2500 mouse pad... Microsoft has offered me no help.. except to pay $450 to trade mine in for a refurbished one.. Unbelievable..
    2016-12-26T14:29:51+00:00
    I wish some consumer protection group would go after them to recall the SP3 because Microsoft knows they have an issue with the battery. But I know that's just wishful thinking.
    2016-12-29T23:44:12+00:00
    I wish replacement batteries were not a couple of hundred pounds but is seems like Microsoft has remedied the problem. By some miracle the battery life doubled, maybe Microsoft fudged the numbers or something, idk.
    To conserve battery life, I use Internet Explorer (surprisingly fluid and light) with the brightness pretty low and it's always in battery saver. I can get 6 hours this way, or 4 hours of video.
    2016-12-30T02:33:06+00:00
    I have done everything posted and everything MS has told e to.   The best that happens was that I went from 89% battery ware to 14.5% after I wiped the HD and installed a new iso of win10.   That was OK for  week or so but it eventually dropped back to 85% battery ware and 10 min use unplugged.
    I gave up.   I sold it and bought a new Dell XPS13.   That makes two companies I will never buy hardware from: Apple and MS.
    I am don with this BS.
