2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-20T00:37:44+00:00
    I noticed this problem over the weekend, then saw the article from Windows Central and followed it here.  It's nice that Microsoft says to contact them, but provides NO method of doing so without a $99 charge.
    And they are not aware of any battery problems when calling, even reciting the exact quote.
    EDIT:
    After 30 minutes of being put on hold the supervisor finally found the email about the battery issues. (After telling me that there was no such alert). He then said that it allowed him to bypass the $99 troubleshooting call charge, but I would still have to pay for a replacement.
  2. Deleted
    2016-07-20T01:40:53+00:00
    EDIT:
    I happened to purchase mine with my American Express, which offers extended purchase warranties, effectively doubling the warranty period.  A bit of a hassle, but if you have anything similar with your credit card, they will pay the potentially reimburse you for the replacement fee Microsoft is charging.  It appears the easiest method is to take the device and form to a Microsoft store, at least with American Express.  Still looking into the details here, but worth investigating for anyone who might not be aware.
    2016-07-20T02:59:24+00:00
    I just called again and was told "it is a known issue that should be able to be fixed via an upcoming Windows Update". I really hate talking with tech support that knows less about technology than I do...
