2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-28T16:18:32+00:00
    Nirut, here's what one of the internal Surface folks said:
    From the data, he had something sucking up an awful lot of his battery in that last active session.  Everything up until the very last session looks fairly normal, but there was something going on in the last session that hit the cpu or disk really hard to drain battery that quickly.
    Rather than a new device, his best bet may be to put his data somewhere (like in the cloud) and apply the latest recovery image.  He’ll have to reinstall apps, but it will get rid of anything unknown that might be pounding on his battery.
    2016-11-10T17:28:50+00:00
    So with the new SP3 firmware released November 8, I still am not getting a good result. Still some pretty excessive drain. Normal browser-only usage today.
    2016-11-14T09:51:19+00:00
    I am having the same problem.   It just started after the SP3 is less than 2 years old.   If I run without the ac charger the battery life drops every time I charge.  I am now at 2:15 full runtime and dropping.  What can I do?    I have tried EVERY suggestion in this and a number of other threads.   No update has had any effect at all.    If I run off the battery it keeps wearing very quickly.
    2016-11-15T20:34:19+00:00
    Hi Barb,
    Firstly thanks to you and all the other MVP's that had made every effort to understand the problem and mediate. My SP3 is 2 and a half years old, and about 6 months ago ran into the same battery problem. It got to a stage where if I unplugged the power, the battery was showing 3 - 4% within a few minutes - likewise if I plugged the power back in, the battery showed 100% after a few minutes. I haven't read every entry in this post, but enough to know that I was ready to dump my SP3 in the toilet. As a last resort, I did a full system repair / restore and I restored it to factory settings. Lo and behold it is like a brand new device out of the shop and the battery is just fine. (I have been able to run off one charge for the last three days). With this in mind, I can't help but think that this is not a battery or hardware related issue at all, but one of software. I have had to rebuild my entire OS, but rather that than have to buy a new overpriced SP4 or SP5. I am happy (albeit still rather peeved at MS). Thought I would mention this in the event any others want to try it.
    Regards
