2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-18T18:42:57+00:00
    I also have one other symptom that I have yet to see mentioned so maybe I'm the only one but if the system is being taxed a bit, the fan will ramp up and then eventually shutdown (not gracefully).
    Did you just jinx me? Just now, had the fan ramp up then Surface shutdown as if I had pulled the plug (but hadn't). Now although it's plugged in, it won't start anymore unless I do the volume + power button trick a few times.
    2016-10-18T18:46:08+00:00
    Which battery do you have? What about the Dock - this S3P that just died was using a dock - wonder if that could be a common denominator?
    2016-10-18T19:01:22+00:00
    I have the LGC battery.  I don't have a dock so that doesn't appear to be related.
    The fan ramp up issue is interesting.  I think that it may be related to a faulty temperature sensor where it is compensating for faulty readings.  So in the case of it shutting down while you're using it, it is reading higher than actual.  Similarly to the that, when starting up from hibernation the temp sensor is not reset and is starting at a higher number and the fan starts immediately and when then temp doesn't drop it accelerates until the system decides to shut off for fear of over heating.  Not until the system is hard rebooted or the power removed does the temperate sensor resets.
    Just a wild theory though.
    2016-10-18T20:07:40+00:00
    My SP3 displays this same behavior with the fan...  Also, if I launch a movie or YouTube the device will shut down hard.  Good Luck
