2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-17T18:16:20+00:00
    My small company has purchased at least 10 Surfaces since they came out (mix of original, SurfaceBooks, 2, 3, all PRO).  At least three of the most recent batch of S3Ps have had significant battery issues. No problems with the other versions.
    One user had it get so hot it almost burned her hand, wouldn't shut down, had to hold power button.
    Another user has had to use the power + volume up buttons trick to get it to start several times.
    One user has the same "Plugged In, Not Charging" shuts off immediately when unplugged battery problem.
    We have followed all the recommended, updates, firmware, Restart now, do they hokey pokey . . . still having problems with batteries.
    These should be recalled.
    I have the Same Issue... No resolution to-date other than, pay for a refurbished unit with a 60 day warranty....
    2016-10-18T02:20:39+00:00
    Dear Barb,
    Excuse me, do you think my case is normal?
    My Surface Pro 3 Simplo Battery have already updated and display this persistent information;
    1. My Surface Pro 3 Charge level jump from 93% to 100% as you can see from the Battery Report.
    2. After unplugging the Surface Pro 3 and using for about 10-20 Minutes, Battery will drop to 92 - 93% immediately. (Never see 94 - 99%)
    Looking for your comment.
    Thank you,
    Nirut Yongsithikorn,
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c3c70189-10cd-4ddf-b10b-60c41cbf599f)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=0dca1ddb-ecdf-4509-aa66-40c299e2e01c)
    2016-10-18T09:11:47+00:00
    is this a Simplo or a LGC battery? post the entire battery report, not just a
    partial. there are obviously still battery issues with the SP3.
    2016-10-18T17:37:57+00:00
    I have the exact same issue where it will not start without being plugged.  It won't come out of hibernate, nor will it start correctly after being shutdown.  I ALWAYS have to hard boot or pull the plug/back in to boot the system.  If I don't then the system will start to the BIOS then attempt to boot.  The fan will ramp up over about 5-10 secs and then it will just shut down prior to getting to the logon screen.  It will keep doing this until I either hard boot or pull the plug/back in prior to booting.
    I also have one other symptom that I have yet to see mentioned so maybe I'm the only one but if the system is being taxed a bit, the fan will ramp up and then eventually shutdown (not gracefully).
