2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-14T14:36:01+00:00
    cycle  count went up after it was shut  off for awhile
    COMPUTER NAME DESKTOP-CB9PEME
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 10586.633.amd64fre.th2_release.161004-1602
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-10-14 10:31:38
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1166416388
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 33,752 mWh
    CYCLE COUNT 93
  2. Deleted
    2016-10-16T23:57:27+00:00
    My cycle count has been going up by 7 and the battery has been losing capacity.
    I purchased my Surface Pro 3 in January 2015 with the extended warranty.  It has a SIMPLO battery. I've always questioned the battery capacity and sometimes during charging it would just stop somewhere at 90-99% and just sit there "not charging".  I would have to disconnect and reconnect to power to get it to charge again. I mostly use it on my desktop with it plugged into the original Surface Pro 3 docking station and my battery appeared to be degrade but not as bad as many reported here (probably because of me using it on power most of the time)  After the battery fix firmware of 09/30/16 was applied, i noticed that my cycle count is rising rapidly.  I had about 75 cycles from January 2015-August 2016..now i have about 150 and it has doubled less than 2 months.
     My Surface Pro 3 also has the "20% cpu" systems & interrupts problem related to the Realtek HD audio drivers. When in the docking station at boot, it uses 20% cpu all the time. I have to reboot to clear that problem.
    Really sorry I invested $1500 or so in this machine.
    2016-10-17T17:19:48+00:00
    My small company has purchased at least 10 Surfaces since they came out (mix of original, SurfaceBooks, 2, 3, all PRO).  At least three of the most recent batch of S3Ps have had significant battery issues. No problems with the other versions.
    One user had it get so hot it almost burned her hand, wouldn't shut down, had to hold power button.
    Another user has had to use the power + volume up buttons trick to get it to start several times.
    One user has the same "Plugged In, Not Charging" shuts off immediately when unplugged battery problem.
    We have followed all the recommended, updates, firmware, Restart now, do they hokey pokey . . . still having problems with batteries.
    These should be recalled.
