2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-14T10:21:35+00:00
    Thanks for your reply dear Indraneel.
    I live in Iran and unfortunately there are no Microsoft stores here.
    2016-10-14T10:25:36+00:00
    Have you found any fix for it?
    The Microsoft doesn't seem to care about it.
    2016-10-14T12:51:13+00:00
    No change to the cycle count this time but is still dropping capacity.
    Battery report
    COMPUTER NAME DESKTOP-CB9PEME
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 10586.633.amd64fre.th2_release.161004-1602
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-10-14 08:48:32
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1166416388
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 33,752 mWh
    CYCLE COUNT 86
    2016-10-14T13:56:17+00:00
    I'd like to see it over the next few days..
