2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-12T16:15:50+00:00
    do you have the jumping cycle counter issue as well?
    >>and now this jumping cycle counter
    2016-10-13T04:05:18+00:00
    Having same issues with my SP3, 18 months old out; not covered by warranty now. Battery is at 0%, sometimes not detected sometimes says plugged in but not charging. Downloaded the firmware 2x, refreshed and reinstalled surface pro 3 tools.
    Spoke with 2 techs, online and in store, both offered a replacement of 550C$+tax. for a USED UNIT AND 90 DAY WARRANTY. The techs pretended they didn't even know of this issues and replied with "thank you, I will forward this to management". Even when if Im able to decide what battery my used device will have, it will likely be some poor user that had the same issue that I will have after a few months with a replacement unit; thanks to internet searches and this forum.
    A replacement and this firmware is no help to this default of Microsoft. Asked to downgrade my device to a S3 and/or laptop; nope it's not possible. Thanks for robbing me Microsoft. I'll make sure to forward all of this throughout the internet. Buying a Mac now, as much as Im not a fan. Their customer support and quality is insured that my battery replacement will be replaced for $100.
    ADMIT YOUR MISTAKES MICROSOFT.
    2016-10-13T05:56:03+00:00
    My cycle count has been going up by 7 and the battery has been losing capacity.
    Battery report
    COMPUTER NAME DESKTOP-CB9PEME
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 10586.633.amd64fre.th2_release.161004-1602
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-10-13 01:42:10
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1166416388
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 34,162 mWh
    CYCLE COUNT 86
    2016-10-13T10:46:37+00:00
    please run your battery down completely until the Surface shuts off on its own.
    then charge over night. turn on and rerun the battery report. post again.
    >>CYCLE COUNT 86
