2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-11T17:53:47+00:00
    I hate to say this, but if you completely reimaged, applied the firmware update, and did a couple of complete discharge/recharge cycles, and still have the issue, I wouldn't hold my breath waiting for a fix-- you'll have to pursue the exchange process. I don't like having to suggest this, but I know of no other options. MS thinks that the Simplo issues are resolved AFAIK. You could open an IT Support case (which costs as much as the exchange and gets refunded if you have a reproducible bug) - but I think you'd end up in the same place you are now.
    2016-10-12T13:18:19+00:00
    2016-10-12T14:15:18+00:00
    thanks, I've emailed them with your results from this test.
    >>Before operation: (You can see that the cycle count has a 7 times' jumping again. Yesterday it was 731)
    2016-10-12T14:47:31+00:00
    I really wish that someone knowledgeable from outside Microsoft could take a closer look at the battery firmware and the recent patches to it. The sudden battery degradation issues, close after warranty time, and now this jumping cycle counter almost YELL "planned obsolescence" at me. These "glitches in the matrix" clearly show, that simple code - intentionally and unintentionally - can cause the battery reporting to report basically anything and at any time to brick a device beyond repair although physically everything would be intact. MS should really come up with actions and pro-active trust-building measures here, not to scare away (potential) customers by the thousands.
