2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-11T16:09:05+00:00
    Sure, I will do this. Please wait for a day.
    2016-10-11T16:18:08+00:00
    if you have a SIMPLO that successfully installed the 8/29 fix and still have
    issues, YOU can open a new thread (include your battery report) but I fear MS
    will treat these no differently than other battery failures out of warranty (pay
    for an exchange). *I* would like to see a battery report.
    >>perhaps Barb should open a new thread for everyone with the "not charging
    Battery report
    COMPUTER NAME DESKTOP-NMKML7N
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 14393.206.amd64fre.rs1_release.160915-0644
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-10-11 12:11:47
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161107972
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 33,828 mWh
    CYCLE COUNT 36
    Recent usage
    Power states over the last 3 days
    2016-10-11 11:29:12 Active AC 61 % 20,801 mWh
    12:11:00 Report generated AC 61 % 20,801 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2016-10-07 - - - -
    2016-10-08 - - - -
    2016-10-09 - - - -
    2016-10-10 - - - -
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-10-07 33,828 mWh 42,157 mWh
    2016-10-08 33,828 mWh 42,157 mWh
    2016-10-09 33,828 mWh 42,157 mWh
    2016-10-10 33,828 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-10-07 - - - -
    2016-10-08 - - - -
    2016-10-09 - - - -
    2016-10-10 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install - - - -
    Not much to see, since I have reset many times and usually I have to go thru an Auto Repair every boot, to get logged in.  Was 99%, not charging since July, now it 62% not charging since the updated firmware and degrading daily by about 2%.
    2016-10-11T17:17:40+00:00
    you really should try a reimage from a downloadable recovery image
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage
    if you see auto repair every boot... then deal with the battery issues.
    2016-10-11T17:31:17+00:00
    I have performed the recovery process twice; however, after the Windows updates and firmware are applied, the issue continues.  The battery issue causes the SP3 to die without shutting down correctly; thus, the two issues are mutually inclusive.
