2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-11T13:03:32+00:00
    MarTech,
    Have a look here to see if you fit this problem.
    If your Battery Report says you have the LGC-LGC Battery and you are Plugged in, not charging please look at this link.
    http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfdrivers/surface-pro-3-with-lgc-lgc-battery-degradation/f4fc3ec9-0771-46a3-8282-eaf588a7457e
    Chris
    It seems people with the same issue are all over the place, here at answers.microsoft.com and on other websites as well.
    2016-10-11T15:13:36+00:00
    Sure. This is yesterday's report. 29769mWh, 724 cycle count.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ce3349aa-04cf-4037-8a69-09dab379b5c6)
    And this is today's report. 29716mWh, 731 cycle count. I'm a Chinese user so don't mind the time. You can see there is a 7 times jumping in just one day. (I reinstalled OS on October 8th)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=d7eec6a3-7b06-4a8c-bac5-1df7a3883d42)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=fe669376-6f79-430a-8950-b612eff95fb4)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8d7aa9ee-cb11-42dd-9018-c47199803c16)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b467df7a-3cd1-4315-bc85-ecebc66ef933)
    There is some more detailed information in sleep study report. May it can help.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=bee669ab-abb4-4773-a9c5-0175be9c0296)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b4fae409-402f-4b48-b86e-c4d71e6d7350)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=966eff7b-225a-4148-8ac7-cda85f258e83)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=87592f98-6419-4f9d-9c6d-1d4de32443d2)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=1f4df3b0-0c36-44fd-b044-8bbde210d0e1)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=27db3ff4-26fc-417c-ba0f-8f8afc9d5a1c)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ffe27c31-f3c9-4014-8786-862ef49a0ae3)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=244743ee-ea4c-4a30-b878-871447b98f6a)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e26938f9-6d39-4841-9fb0-1234d0e81b95)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=9658efbb-7860-4b88-bcd8-f4b584595a38)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=dbb0ca39-7265-43ff-b545-d235dd585a92)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f362556e-ae7a-47b0-9847-66a44cb0fcd6)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=4b57ee7d-eda2-4b11-80a8-833766803912)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=6f7312d4-b63d-4ea6-89d5-91d43c6053c2)
    2016-10-11T15:38:01+00:00
    I've sent this in, but please keep posting just the top portions showing cycle
    counts. (I'm doubtful that -if I get an answer at all- that there will be a
    solution OTHER than out of warranty support - Microsoft is not commenting on nor
    has anyone successfully been able to get the promised $200 out of warranty
    battery replacement that the Surface Team committed to at launch
    https://www.reddit.com/r/IAmA/comments/26m9cu/we_are_panos_panay_and_the_surface_team_at/chsei5u
    2016-10-11T15:53:17+00:00
    I got a quick reply - they asked that you run the machine and don't turn it off and let it shut down when the battery depletes on it's own (so maybe put it in an always on power management mode). Then fully charge (overnight?) and see what the numbers show (post them).
    Can you do this?
