2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-10T16:16:24+00:00
    I've ignored nothing. I'm an unpaid volunteer, just like all MVP's/Community
    Moderators. I've done everything I can but I can't force Microsoft to update the
    thread or issue fixes. I personally have a SP3 that I bought myself with an LGC
    battery. So believe me, I escalate - but there is nothing I can do other than
    that.
    >>and Barb a long time ago.  It appears to have been ignored.
    2016-10-10T16:18:05+00:00
    my reply was to WENKUITIAN
    if you want to do a battery report, open an admin cmd prompt and run
    2016-10-10T16:29:51+00:00
    Barb, are you having the same issues I am having with the LGC?
    It will not even start without being plugged in.
    The battery status when plugged in is now at 40% and not charging.
    I have also noticed if you let it hibernate, it will not come out of it without a hard boot that will always bring up the bios screen.
    2016-10-10T18:01:13+00:00
    I'm having a different issue.
