2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-21T12:40:16+00:00
    The bottom line is if you did not buy an extended warranty, then MS expects you to pay more than the cost of the extended warranty to teach you a lesson...
    2016-09-24T02:04:13+00:00
    Hi DatabaseJase,
    Does it mean the SP4 power cable will help as it will supply enough charge so as not to drain from battery while on AC power?
    2016-09-24T11:20:22+00:00
    I find it highly interesting that this many folks would have a problem with a product that is not repaired by any of the proposed fixes. Additionally, most of these folks have to pay $100 to get someone on the phone and no repair. Once that inevitably fails, they are told to fork out another $480+ to get another one?!? This is a prime example of how to NOT keep your customer base. I will be notifying my peers and professional/personal family. Stay away if you are the lucky few to just be reviewing a product before purchase!!
    -Highly dissatisfied
    2016-09-24T13:13:44+00:00
    I agree.
    And MS only seem to be acknowledging issues that get exposure in media, otherwise they just stay silent and/or tell us to pay $450-550 for a replacement machine.
