2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-13T10:22:50+00:00
    Plug in and see if you can boot to UEFI and STAY on that screen for 8 hours with the charger plugged in and see if you can get some kind of battery charge
    How do I get to the UEFI settings?
    The UEFI settings can be adjusted only during system startup. To load the UEFI firmware settings menu:
    Step 1: Shut down your Surface.
    Step 2: Press and hold the volume-up button on your Surface and at the same time, press and release the power button.
    Step 3: When you see the Surface logo, release the volume-up button. <br><br>The UEFI menu will display within a few seconds.
    if that does not work, please open an admin cmd prompt and run
    copy and paste the ENTIRE report into your reply.
    2016-09-13T18:07:18+00:00
    It will not turn on at all.  Unfortunately, it's my son's.  He noticed shorter battery life, but did not say anything until it stopped charging altogether, and the battery is totally dead now.
    2016-09-14T04:46:48+00:00
    Hi Barb , do you have any why different regions of Microsoft would charge vastly different prices to fix this situation? I've had no contacted from Microsoft Japan in over a week and they haven't no responded to any of my emails that I've sent to them.
    2016-09-14T11:09:42+00:00
    sorry, no idea and no way to find out anything.
