2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-10T07:38:31+00:00
    I am happy to say that after the update and 7 cycles of discharge and charge, my SP3 battery indicator is (kind of) running normally. It appears to me that different SP3 exhibits different behaviours to the update. So I am sharing some observations for mine over the last many days after the update.
    The first 5 cycles has been erratic. For the first 2x, the SP3 shutdowns automatically at around 40%, having being stuck at 99% for 2 hours and next 2 hours moves from 99% to 40%. Subsequent ones had battery indicator working ok but life drops to about 2-3 hours.
    The last cycle, I can use the SP3 for 5 hours straight, battery % drop looks normal, time remaining is as unbelievable as always so no big deal. Not sure if this catastrophe caused damage to my battery already, but I guess my SP3 is one lucky survivor of this disaster. I will certainly continue to monitor though, just to be sure my SP3 is ok. It's a lovely piece of kit.
    Maybe we need more patience. Wish everyone good luck and your SP3 speedy recovery. :)
    2016-09-10T13:12:23+00:00
    Quick update: 4 days later I received a brand new S3P. It seems that they were not willing/able to fix it.
    2016-09-10T13:48:24+00:00
    This was unhelpful and did not work. My Surface Pro 3 continues to show "plugged in - not charging" and if I remove the charging adapter cable the unit immediately shuts down.
    2016-09-11T02:30:14+00:00
    Did Microsoft replace your SP3?
    If so, how much did they charge you?
    I'm still being quoted almost $800  by Microsoft Japan, that's outrageous and totally unacceptable.
    Microsoft Japan said that they have to talk to the battery manufacturer about my situation, that was 5 days ago and not a phone call or an email.
