2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-04T20:33:07+00:00
    Yes, I have spoken to people in other online communities and we are definitely not alone with this issue. Apparently it have been a problem since the launch of the Surface Pro 3, and I have also spoken with owner of the SP4 with the same problem. Hopefully MS will resolve it eventually, and not abandoning the SP3, as not being able to tell the battery level is extremely frustrating.
    2016-09-05T07:18:41+00:00
    I sent an email, not the same as opening a ticket. I don't always get detailed
    feedback, mostly "engineering is looking into this".
    That would do. Any help from you is welcomed.
    Just note that "Battery Not Detected" is though less but not an uncommon sight among the Surface Pro 3 users.
    I am one of those frustrated and agonised users who is sitting with a 2000 dollar slate that within one and half year of its purchase won't run without AC power and may die anytime soon as the battery issue is not resolved yet.
    I still believe that if MS can remove this minimum 40% battery power restriction with a registry tweak, the update for the battery can be applied without hitch.
    It defies logic that an updated firmware supposed to replace a faulty firmware on a battery cannot be installed because the device doesn't hold 40% battery power, which is most probably a staus shown by the faulty firmware, thus defeating the purpose.
    2016-09-05T09:45:07+00:00
    Hi everyone,
    since Friday, I have a similar issue. I witnessed a lower battery performance in the last months, but usually the battery worked for more than 2 hours, so, I was fine. Now, I left my Surface 3 Pro, Model 1631, at my desk without charging and it seems that, since the charging level was above 40%, it automatically started some updates (probably the "fix"). The next day, I could not start the Surface even when the charger is connected. As written earlier by others, the charger's light fades for a short moment ca. 10-15 seconds after pressing the start button. As a result, I cannot access any menu (despite my data) or settings.
    So, for me, the update made it significantly worse. Does someone experience the same problem, i.e., an entirely dead battery and a non starting Surface even when the charger is plugged in?
    Thanks!
    2016-09-05T10:04:09+00:00
    its' really important that you try a different charger to see if that is the
    issue. you can go to a physical retail Microsoft Store if you are in the US to
    do this. or use a friend's SP3, SP4, or Surface Book charger.
