2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-09-03T08:02:08+00:00
    Just wanted to give feedback that I lost another 1000 mWh of battery capacity in one cycle.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=4cac9b41-ecb5-4eb0-9d95-a003f450bf2c)
    My Surface Embedded Controller Firmware driver is the latest
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=9d4df900-9d42-464b-a89a-0da3b908d1cf)
    Maybe the fix is only good for the batteries that hit the bottom?  Did anyone else have a similar experience?
  3. Deleted
    2016-09-03T08:21:50+00:00
    I was hoping the new firmware update would solve my problem but it did not. I have tried every solution I have found here, but no success. The problem is that my battery indicator is stuck at 99% regardless of usage.
    Here is my battery report:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=cd2873a3-bf13-4538-a8ff-50f2bb1340ae)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=615a562c-c8ce-44c7-a34f-c645ed4d54fa)
    As you can see, the capacity is stuck at 35895mWh.
