2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-31T15:35:03+00:00
    Interesting, my current capacity after the firmware update is also 35,910 mWh (after 160 cycle count).
    Something strange going on with this number.
    2016-08-31T16:29:06+00:00
    is not fix with LGC battery
    2016-08-31T17:43:35+00:00
    talking to myself but just heard they are still working on things. it may be a
    while. sorry.
    >>Engineering is putting some steps together for you and Linda to try. They said it will be a few hours (it's only 7am in Redmond). I'll post when then provide the process.
    2016-08-31T17:44:58+00:00
    I need you to start a NEW thread with LGC battery as part of the subject. Then completely describe your issue and post a battery report
    powercfg /battery report
