2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-31T02:27:44+00:00
    I was able to update mine.  it seemed to take 2-3 attempts, seemed like it may have been updating other things before it got to the firmware update.  updated and then I charged overnight and it charged to 35,910 mWh.  I left it on when I left (7:06am), went into standby until I got home the end of the workday at which it had drained to 28,462 ((5:15pm).  brought it out of standby then and now at 7:19 its still at 24,472mWh.  this is better than it's ben in a long time since it worked like this!
    2016-08-31T06:38:35+00:00
    It work for me.... after i update the latest update, i had also updated the window 10 anniversary update.
    Do generate a report before you update the window.. as after updating window, the report is started with new window...
    2016-08-31T10:46:55+00:00
    Please start a new thread named LGC Battery Issue - paste in the complete
    batteryreport. I'll be looking for it. Engineering asked to separate out LGC
    from the SIMPLO thread.
    >>Is Microsoft going to take ownership of this problem and fix it like the Simplo’s?
    2016-08-31T10:47:38+00:00
    what is the status now? did it complete?
