2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-31T00:48:18+00:00
    Well Greg and Matthew!
    What is the plan for the LGC Surface Pro 3’s?
    I have done everything that has been mentioned including the patch yesterday!
    Yes, I have removed the battery driver.  I then ran Windows Update, no new driver was installed.  When I scanned for hardware changes, it reinstalled the device driver.
    I let it sit and charge on power adapter for 24 hours.  Turned it on, and it booted to the bios screen.  I saved changes and restarted a couple of times, and it booted on the power adapter.
    It is a brick now and will not even boot now unless the power adapter is plugged in.
    My battery still says 61% plugged in and not charging.  I mentioned this several times yesterday and received no solutions.  Several other uses have mentioned the same issue in this forum.
    Is Microsoft going to take ownership of this problem and fix it like the Simplo’s?  Or is Microsoft going to screw us?
    2016-08-31T00:49:03+00:00
    I find it very odd that many people reported a bottom of 144 mWh before the firmware update and 35,910 mWh after the firmware update.  Since these are the numbers I show it has stood out that so many others have the same.  Why would this be?
    As I stated earlier, the 144 mWh would be the minimum calculated charge level by the buggy charge calculation algorithm that would have been replaced by a hard coded minimum in the fix, to get the batteries to charge and show a capacity, way above 144 mWh.
    2016-08-31T00:59:15+00:00
    I just had a look at this page and there's nothing to say how long it will take, an idea of how long would be great. I know it says a few minutes but mine is coming close to an hour now and its still sitting on the "Please wait... " screen. There is a white ba all the way under the word 'Surface' that has been there for a long, long time. The fan is going nuts blowing cold air and I dont know what I should do.
    Mine took minutes, but the first step is downloading the binaries and this may take some time, depending on your connection speed. A reboot then occurs, with little warning. Scarily, during the restart, the firmware gets upgraded and you see a black screen with a progress bar, but with mine, the fan kicked in before the bar was full. This normally eats what little charge remains in the battery and the device shuts down. Right at around 100%, the device switched off and it was so quick I couldn't determine if it actually reached 100% and whether this was a scheduled reboot, or if it died before reaching 100%. Anyway, it came back up, the startup spinner displayed, then Windows was upgrading. At 100% I got the login prompt and was done. I logged in and the battery was charging, but only took 2 minutes to reach 100%. This meant my battery was charged all along and my device was shutting down because the battery driver thought it was empty, when it wasn't. That's annoying in itself; knowing my battery was actually charged the whole time, but the tablet wouldn't use it because of a software/firmware bug.
    2016-08-31T02:05:03+00:00
    Mine went down to 143 and bounced back up.  Why would so many people go to exactly 35,910 with the firmware update?
