2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T21:08:00+00:00
    Hello everyone,
    Thanks again.
    Greg
    Updated 8/29/16.
    No help  My battery is completely dead.  I have shut down my system and then tried to restart.  The unit will not hold a charge.  What should I do.  this pro 3 is only a year old.
    I followed the update process and nothing has changed, battery 99%, plugged in not charging.  I verified that the firmware was installed and restarted several times.  I even performed a Reset, erasing all my old files, then allowed Windows Update to update everything including the Firmware.  No luck, now what?
    2016-08-30T21:10:15+00:00
    Open an admin cmd prompt and run
    Post the complete output here.
    2016-08-30T21:54:58+00:00
    Battery report
    COMPUTER NAME MY-SP3
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 14393.82.amd64fre.rs1_release.160805-1735
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-08-30 17:56:21
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161107972
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 33,828 mWh
    CYCLE COUNT 36
    Recent usage
    Power states over the last 3 days
    2016-08-30 09:40:16 Active AC 99 % 33,645 mWh
    09:40:16 Suspended 99 % 33,645 mWh
    10:46:54 Active AC 99 % 33,645 mWh
    10:57:00 Battery changed AC - -
    10:57:00 Suspended - -
    11:01:12 Battery changed AC 99 % 33,645 mWh
    11:01:12 Active AC 99 % 33,645 mWh
    11:01:12 Suspended 99 % 33,645 mWh
    12:00:01 Active AC 99 % 33,645 mWh
    12:00:01 Suspended 99 % 33,645 mWh
    12:01:31 Active AC 99 % 33,645 mWh
    12:11:34 Connected standby AC 99 % 33,645 mWh
    12:25:30 Suspended 99 % 33,645 mWh
    13:40:25 Active AC 99 % 33,645 mWh
    13:40:25 Suspended 99 % 33,645 mWh
    13:45:09 Active AC 99 % 33,645 mWh
    13:45:09 Suspended 99 % 33,645 mWh
    13:47:32 Active AC 99 % 33,645 mWh
    13:47:32 Suspended 99 % 33,645 mWh
    13:48:18 Battery changed AC 99 % 33,645 mWh
    13:48:18 Active AC 99 % 33,645 mWh
    13:48:18 Suspended 99 % 33,645 mWh
    15:10:38 Battery changed AC 99 % 33,645 mWh
    15:10:38 Active AC 99 % 33,645 mWh
    15:22:00 Suspended 99 % 33,645 mWh
    15:23:08 Active AC 99 % 33,645 mWh
    15:23:08 Suspended 99 % 33,645 mWh
    15:25:47 Active AC 99 % 33,645 mWh
    15:30:00 Battery changed AC - -
    15:30:00 Suspended - -
    17:55:53 Battery changed AC 99 % 33,645 mWh
    17:55:53 Active AC 99 % 33,645 mWh
    17:55:53 Report generated AC 99 % 33,645 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    Battery capacity history
    Charge capacity history of the system's batteries
    Battery life estimates
    Battery life estimates based on observed drains
    Current estimate of battery life based on all observed drains since OS install
    Since OS install - - - -
    2016-08-30T23:14:00+00:00
    Hi Barb,
            I just followed the same steps proposed and it didn't help me :( I get a message "Battery Not Found" in the system tray :( Tried rolling back to 8.1 and updating to 10 and reset , restore :( Nothing worked ....
