2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T19:25:57+00:00
    I find it very odd that many people reported a bottom of 144 mWh before the firmware update and 35,910 mWh after the firmware update.  Since these are the numbers I show it has stood out that so many others have the same.  Why would this be?
    2016-08-30T20:08:38+00:00
    I just had a look at this page and there's nothing to say how long it will take, an idea of how long would be great. I know it says a few minutes but mine is coming close to an hour now and its still sitting on the "Please wait... " screen. There is a white ba all the way under the word 'Surface' that has been there for a long, long time. The fan is going nuts blowing cold air and I dont know what I should do.
    2016-08-30T20:29:44+00:00
    Hello everyone,
    Thanks again.
    Greg
    Updated 8/29/16.
    Thanks Greg to keep us posted.
    This morning upgraded the Firmware and battery jumped from 182 mWh to 35,910 mWh and 105% capacity.  This after 609 cycles.
    Have not tried unplugging and check time on battery power.
    Hey, me too about an hour ago. Found Windows doing an update but no indication that it was the long-awaited firmware update but suspicions aroused when battery did not lose charge when I accidentally unplugged from docking station. Luckily (having just read the instructions rather too late) it seems to have done the trick without my being aware of it. Gone from 14 mins remaining after unplugging from 100% to 6hr 38 mins! Other little changes I'm going to have to sort out now but minor compared to having the world's most expensive doorstop!
    2016-08-30T20:53:53+00:00
    So now it says the firmware update has failed. Is there a way I can re-install it? I tried checking for updates and it doesn't give me an option to install the firmware update anymore.
