2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T18:19:23+00:00
    So every time I restart my computer to finish installing the update the screen flashes " please wait while we install an update" then the computer restarts, and it does that a few times. The progress bar only moves up a little bit before the computer restarts so the update cant finish' installing. Any idea what I can do to solve this?
    2016-08-30T18:43:50+00:00
    Hello everyone,
    Thanks again.
    Greg
    Updated 8/29/16.
    No help  My battery is completely dead.  I have shut down my system and then tried to restart.  The unit will not hold a charge.  What should I do.  this pro 3 is only a year old.
    2016-08-30T18:57:14+00:00
    From databasejase
    I used the power supply, not the dock, then I turned on my SP3 holding down the power & volume up physical buttons and then released only the power button (keeping volume up pressed) when Surface logo appeared.  That should open the UEFI/BIOS screen & that is how I left it for 10-15 minutes to "charge". Then I used Ctrl-Alt-Del to restart the SP3 and waited for Windows to start.  If I recall correctly it registered about 20% charged at that point and continued to "charge" until it was above the 40% at which point I could install the update.
    Remember to restart again after the update has installed (you should see the white progress bar below the Surface logo since this is a firmware update NOT a Windows Update) to allow the new driver to fully take affect.
    2016-08-30T18:58:09+00:00
    Hello everyone,
    Thanks again.
    Greg
    Updated 8/29/16.
    Thanks Greg to keep us posted.
    This morning upgraded the Firmware and battery jumped from 182 mWh to 35,910 mWh and 105% capacity.  This after 609 cycles.
    Have not tried unplugging and check time on battery power.
