2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T15:52:37+00:00
    So my charge status says %9 available - plugged in. not charging so I cannot install the firmware update. What should I do? Is there another way to install it without have a 40% charge?
    2016-08-30T15:56:36+00:00
    Remove the batfery devicr from device manager then try again
    2016-08-30T15:57:53+00:00
    I have 0%  not charging
    I had to  disable the battery driver then installed the update
    2016-08-30T15:58:34+00:00
    Try Databasejase's solution
    That suggestion is for those that could not run under load through the dock so if you hadn't reached that point and the update installed successfully (check Windows Update history to see if it succeeded) then you're fine.  The reason it was suggested to use the power supply, not the dock, was to prevent the SP3 powering off during the update (for some of us that was a real risk as we only had around 5 seconds of run time on battery).
    Anyone who is struggling with an SP3 that won't even power on now this is what I did to get the update installed:
    I used the power supply, not the dock, then I turned on my SP3 holding down the power & volume up physical buttons and then released only the power button (keeping volume up pressed) when Surface logo appeared.  That should open the UEFI/BIOS screen & that is how I left it for 10-15 minutes to "charge". Then I used Ctrl-Alt-Del to restart the SP3 and waited for Windows to start.  If I recall correctly it registered about 20% charged at that point and continued to "charge" until it was above the 40% at which point I could install the update.
    Remember to restart again after the update has installed (you should see the white progress bar below the Surface logo since this is a firmware update NOT a Windows Update) to allow the new driver to fully take affect."
