2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T12:41:18+00:00
    if you think you have an issue with LGC, can you please start a new thread, supply some details and also post the results of
    looks like the problem still persist with LGC LGC batteries... oh my..... for those who is with LGC LGC batteries, I think  you should group together to tell the problem to Microsoft Greg. the problem might still persist for LGC LGC batteries. the patch may only have solve the problem for SIMPLO batteries only.
    2016-08-30T12:45:44+00:00
    good idea on a couple of rundown/recharge cycles. my concern is that if a tweak
    is needed for LGC, this thread is way too long and we can get Microsoft to pay
    more attention if we start a thread solely for LGC. (I'm asking an internal
    contact what LGC owners should expect).
    >>I'm not sure that is correct, some SP3 owners with LGC batteries also reported degradation too.  In response to Wildsoldier I'd say have a little patience and try running the battery down and then charge to 100% again and according to MS you should see the battery re-learn it's real capacity.
    2016-08-30T12:52:48+00:00
    Max, can you post the output of your battery report?
    I don't think this is the exact issue that is impacting the folks with SIMPLO.
    It's going to be really hard to evaluate LGC variations/issues inside this
    existing thread, and it would be easier to escalate if there was a separate
    thread.
    2016-08-30T12:53:11+00:00
    looking at people with LGC LGC batteries problem, I still don't dare to do the update. I was using my previous method and able to maintain the full charged capacity at about 39.7k battery. I don't want to screw up what i'm having now...
    i'm also afraid that people with LGC LGC batteries are too little... doesn't seem many appear in this thread....
