2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T11:47:59+00:00
    Very interesting, because they have the same capacity as you. I think I set the battery degradation. Microsoft did not want to give us the full capacity of the battery.
    2016-08-30T11:50:33+00:00
    Have you applied the update and restarted (twice)?  Did you at any point before installing the update delete the battery driver?  If you did I'd suggest doing so again and then restarting the device to let it be detected.
    You might have to keep running the battery down so that it can charge again from empty.
    2016-08-30T12:03:53+00:00
    Does anyone really believe these conspiracy theories?  Why would Microsoft do such a thing?
    I have a big issue with how this #BatteryGate incident was handled by Microsoft in terms of the length of time to provide a fix and the lack of information flowing from them.  I do not believe for one minute that Microsoft intentionally caused the software fault in an attempt to sell new hardware.  The damage done to the Surface brand over this will take months, maybe years, to recover with many business people posting in these pages how they have stopped purchasing Surface devices for their employees.
    Microsoft is a business and any practice of building in obsolescence can only ever be counter productive to their business goals.  The SP3 I have is a business purchase and believe me it will be a while before I make another Surface purchase but it isn't because I feel they did this deliberately.
    2016-08-30T12:05:25+00:00
    looks like the problem still persist with LGC LGC batteries... oh my..... for those who is with LGC LGC batteries, I think  you should group together to tell the problem to Microsoft Greg. the problem might still persist for LGC LGC batteries. the patch may only have solve the problem for SIMPLO batteries only.
