2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T11:17:35+00:00
    Thank You for the Answer, but I have an LGC battery and my battery stays at "82%, Not Charging", but it'll instantly turn off when I unplug the power source; so for me Simplo or LGC makes zero difference
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=9ef2c073-5f22-4e30-988d-02a9d13e0a9c)
    2016-08-30T11:31:59+00:00
    Can you please start a new thread with this issue?
    2016-08-30T11:41:20+00:00
    Suggest you start a new thread, different issue.
    I'm not sure that is correct, some SP3 owners with LGC batteries also reported degradation too.  In response to Wildsoldier I'd say have a little patience and try running the battery down and then charge to 100% again and according to MS you should see the battery re-learn it's real capacity.
    If not then report back as there is a possibility that a tweak to this fix is required for LGC batteries.  Depending on the results it might be appropriate to start a new thread to highlight LGC.
    2016-08-30T11:47:32+00:00
    Barb has done her best to help raise this issue, especially being very vocal on Twitter to gain publicity through high profile Microsoft bloggers, so I know she has the best intentions.  All that despite her own SP3 being completely unaffected by this battery degradation issue.
    I have not read Barb suggesting anyone service their own machine or suggest that people should pay for a replacement.  I personally don't find her comments condescending so perhaps there is a language barrier or perhaps sometimes due to the volume of help the MVP's provide they only have time for answers that are direct and to the point.
    I would certainly not describe Barb as biased and I'm sure we have her to thank that Microsoft took notice of this.
