2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T02:34:31+00:00
    Well done Microsoft and the Surface team. This update has fixed the issue on my Surface. I very much appreciate the extended effort and continued work put forth to deliver this update to all SP3 users!
  2. Deleted
    2016-08-30T03:03:20+00:00
    I wasn't able to stop the auto update and was docked on the docking station when it asked for a restart. I restarted and then just read now that it was suggested that I was plugged in and not on docking. What can I do now?
    2016-08-30T04:46:11+00:00
    I have mine applied with both external monitor and usb cable to monitor hub connected. There should have been a pop up at windows update about this. Nonetheless, after the second restart it immediately reported 35910 mWh and 100% charged which is about 5% short of where I should be based on my calculations. I should have around 10% wear instead of current 15%.
    Will see what the next couple of charge cycles bring along. Good to type anywhere and do less stretching because of constant sitting...
