2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T01:04:20+00:00
    Matthew,
    It just sat on the charger for 1 hour, totally shutdown.
    No difference.  It still will not charge.
    Awaiting your guidance.
    2016-08-30T01:30:21+00:00
    Another thing to try if that doesn't work is to keep the surface unplugged for a while then continually try starting it while it is not plugged in. Try to start it 5-6 times. You will just get the dead battery screen, but keep doing it. Then plug it back in and start it up. Sometimes this will also trick the firmware into holding enough charge to log in. My surface is the only computer I have and its been dead for a month, so I have had a lot of time to experiment with it and try to get it working.
    @SeanDavis33 this worked for me!  The fiddling with the power cord at startup did not, but this did!  I had to attempt this method twice though.  The first time I tried it I got past the login screen and couldn't believe it.  Then after Windows loaded it cut off (cried).  Then on the second attempt it went all the way through and showed 100% battery, imagine that.  First thing I did was download the new firmware from Windows Update.  It asked me to restart which made me nervous.  Nonetheless, here I am working again with the new firmware.  Thanks for the tip!!  The Microsoft site also said to do a second manual restart to get the full effect of the firmware update.  Here goes...
    2016-08-30T01:38:42+00:00
    Also, make sure you restart twice after new firmware.  The Microsoft announcement on this page recommends 2 full restarts.  Here are the instructions per the announcement in case it goes away.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3400007d-81a5-4d94-aebd-8eda48b27bee)
    2016-08-30T02:12:44+00:00
    Applied new firmware and it fixed it! Typing on battery power now!
    Unfortunately for my budget, I got a Dell XPS15 which is now my main laptop. :)
