2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-30T00:27:25+00:00
    Matthew, thanks. Can you advise where to go to discuss upgrading to Win10? The free upgrade for 8.1 users expired, and those of us who couldn't update because our computers wouldn't stay on lost out. Any way to extend the period for SP3 users?
    2016-08-30T00:41:40+00:00
    Null_RG, I don't have a solid answer for you.  I recommend visit the Windows 10 forums:  http://answers.microsoft.com/en-us/windows/forum/windows_10  or calling Windows Support.  If you didn't upgrade to Windows 10 during the free period, a Surface agent will only be able to reinstall the OS that originally came with your SP3.  Sorry, let us know how it goes.
    2016-08-30T00:47:59+00:00
    If you are STILL seeing issues I would recommend starting a new thread and then coming back here and linking to your new post.
    2016-08-30T00:50:22+00:00
    Use this link:  https://www.microsoft.com/en-us/accessibility/windows10upgrade  and see if that works to get you to where you want to be.
    I have been told that Microsoft [specifically in regards to the Windows 10 upgrade not specifically with Surface devices] will be lenient in cases where there was some sort of block to keep you from Windows 10.  If you have any issues with the upgrade process, holler.
