2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T23:52:29+00:00
    Matthew,
    I have been through these links.  The patch was installed today.
    The trouble shooting has probably been done 15 times in past month.
    Still no changes.
    2016-08-29T23:55:47+00:00
    Hello everyone, now that the fix has been rolled out to near everyone, would it make sense to either start a new thread or refrain from posting on this one unless there are any new issues?
    Like all of you, I am overjoyed that MS has fixed this but the posts are getting repetitive. I don't want to unfollow this thread in case there is any important information posted.
    Best,
    Anjan
    2016-08-30T00:23:42+00:00
    Martech,
    Have you tried deleting the battery drivers as some here have said this fixed their charge status.  please keep us posted.
    Mathew
    2016-08-30T00:26:48+00:00
    I applied the update and the charge capacity on the battery report went to 34,200 and the charging progress claimed it would take 5 hours to charge. This was exciting because anything more than 2 minutes to charge, is progress.
    However, 2 minutes later and my battery is at 100%. Now it either charged quickly, or my battery is hosed and the report is just a bogus number, Microsoft has defaulted the minimum to, so it no longer shows 144mWh.
    Either way, I'm about to remove the mains power to see if it just shuts off, at which point, the update would not have fixed my surface.
    Results to come ...
    Well, it's still working and the battery states I have 7 hours left.
    After 5 minutes use, 6 hrs 48 left, but strangely, still at 100%.
    5 minutes more and it's now 5 hours, 42 minutes left at 100%
    A few minutes later, 4 hours, 10 minutes at 100%
    A few minutes later, 5 hours, 58 minutes at 100%. (I closed IE with the battery report.)
    A few minutes later, 6 hours, 21 minutes at 100%. (still not plugged in and nothing open except Chrome with this page.)
    All I'm doing is sitting here, typing this and waiting a few minutes to check the battery indicator, which changes dramatically after only a few minutes.
    This means I've probably got around 35 minutes on batteries, before it shuts off. Maybe successive charges will extend the duration?
    I can only conclude that my battery has been fully charged all this time, but reported as 144 mWh by the buggy firmware that results in the device shutting down.
    Despite the inordinate amount of time to fix and the prolonged loss of use it caused, thank you for fixing the bug, Microsoft and restoring my device to a usable state.
    I suspect there will be a more stable fix coming in the future where 7 hours remaining will actually mean around 7 hours.
