2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T23:23:49+00:00
    Where are you seeing/not seeing the charging bit
    2016-08-29T23:25:49+00:00
    2016-08-29T23:28:05+00:00
    when I click  the battery icon   on the bottom  right
    2016-08-29T23:36:17+00:00
    new firmware fixed. replying while on battery now
