2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T22:44:51+00:00
    how do i get around the 40% requirement my battery is 0% not charging
    edit -- I deleted the battery driver then ran the update
    2016-08-29T23:08:53+00:00
    Very excited!  On battery power for the first time in months!  Over 30 minutes and still showing 100% power, in economy mode.  I hope everyone gets this kind of result from this fix !  I was very vocal of MS and frustrated, now I must be the same for their result.  They heard us on this board and at their stores and came thru.  Good job.  GLTA !!!
    2016-08-29T23:12:57+00:00
    Matthew,
    I have applied the update as instructed.  My SP3 with an LGC-LGC indicated 61% and not charging.
    Why?
    2016-08-29T23:19:36+00:00
    LGC battery here as well
    I had 97% and plugged in not charging  a few months ago when it stopped working on battery power
    now its 0% and not charging the plugged in bit has  dissapeared
