2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T22:01:17+00:00
    @DatabaseJase,
    Never mind, I figured it out. In case anybody else wants to check, check this article:
    How to generate a Battery Report in Windows 10
    Very straight forward!
    Curious to see if this will every be expanded to 42,157 mWh rather than 34,200 mWh but at least it's a huge improvement from what it was. I think I read from someone else that this had dropped to the guts of 1800 mWh!!
    Hopefully, another firmware will improve this later.
    2016-08-29T22:04:10+00:00
    Right mouse click over Start... Left click "Command Prompt (Admin)"... Then type:
    That will provide a file location which I copy then WinKey+R and paste the file path and name then left click OK.
    2016-08-29T22:05:21+00:00
    Exactly the same number for me, full charge capacity at 34,200 immediately after applying the update. up from 828 beforehand.
    I'm glad (though not entirely convinced until I've given it some more testing) that MS have finally got around to fixing this, since I've been limited to working on a 5 year old netbook, for the last few weeks. It's a little worrying that a fix to a problem that made devices unusable was downloaded in about the time it took me to click the 'check for updates button' and yet took 3 months to release. But thank you microsoft for getting there in the end. I'm struggling to find anything more positive to say about the matter. Another day wasted migrating my work back to the surface.
    Fingers crossed, but all looks good at first glance !
    2016-08-29T22:08:02+00:00
    A lower mWh is expected after the first reboot.  Once the new firmware is in place, it has to relearn your battery capacity.  This takes several charge/discharge cycles.  There's more information in the Surface Pro 3 Battery FAQ article.
