2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T21:28:13+00:00
    At last, although it appears even now Microsoft can't get customer service right; where is the post from Greg informing us officially that this is rolling out and is indeed the fix we've all been waiting for.
    Anyway, after an hour of trying I finally got my SP3 to stay on long enough to check for updates and download and install the 29/8 firmware (I used the power supply not my dock to power the device).  Here are my before and after capacities:
    Before.........
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=2f196589-01db-4f00-9a70-64ae1825f151)
    After..........
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=35465972-9e26-420b-ad2e-71673a61e848)
    This isn't a 100% recovery to where I was before all this started but I am, with a huge relief, finally typing this on battery with 100% charge and 5 hours 28 minutes estimated time remaining (seems to be stuck on that so perhaps the full charge capacity will recover further after a few cycles.
    While I'm certain they will not discuss this publicly I do hope that internally they take a long hard look at this because this should have been picked up by analysing returns, analysis telemetry and through this long running topic.  Surface team you have a long way to go to regain my trust and at this time I do not expect to purchase another Surface device again in the near future.
    2016-08-29T21:35:09+00:00
    Interesting... Stuck on the same value here... 144 before FW, 34200 after, and showing 35910 capacity, and after first reboot, just like you, 35910 max now on my setup with 499 cycles... SP3 i7 256Gb purchased in France, a liitle more than a year ago... This is probably how our battery should look like, I guess.
    2016-08-29T21:52:02+00:00
    @DatabaseJase,
    As a matter of interest, where are you getting this information from? Is this an app? Can you share the link where to get it from?
    Thanks.
    2016-08-29T21:57:28+00:00
    Exactly the same number for me, full charge capacity at 34,200 immediately after applying the update. up from 828 beforehand.
    I'm glad (though not entirely convinced until I've given it some more testing) that MS have finally got around to fixing this, since I've been limited to working on a 5 year old netbook, for the last few weeks. It's a little worrying that a fix to a problem that made devices unusable was downloaded in about the time it took me to click the 'check for updates button' and yet took 3 months to release. But thank you microsoft for getting there in the end. I'm struggling to find anything more positive to say about the matter. Another day wasted migrating my work back to the surface.
